catch can return
Old Sep 12, 2007 | 09:02 PM
powerdbygarrett's Avatar
Default catch can return
so i picked up my block today and im looking at the back of it and cannot figur out where i would put the fitting into the back of the black for the oil return from the catch can (ie: vented valve cover) can someone show me a pic of whos done it? thanks
Old Sep 12, 2007 | 09:08 PM
preludefien
Guest
Posts: n/a
Default Re: catch can return (powerdbygarrett)
are you running turbo
Old Sep 12, 2007 | 09:15 PM
Default Re: catch can return (preludefien)
yea
Old Sep 12, 2007 | 09:18 PM
preludefien
Guest
Posts: n/a
so what do you want to know...were to put the return line...the easiest thing to do or what i did was weld a spout to the front of the oil pan. loosing oil is something that you dont want to play around with..
Old Sep 13, 2007 | 07:12 AM
i dont think ur understanding what im trying to ask. i think i'll just ask it in the vented valve cover thread
Old Sep 13, 2007 | 01:23 PM
nikolai.'s Avatar
i assume you have an h series block. they dont have the crankcase ports on the back of the block like B series have....if that's what you were thinking. The best thing to do for a return is to make another bung in your oil pan to drain the can into.
Old Sep 13, 2007 | 01:46 PM
Default Re: (nikolai.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. &raquo;</TD></TR><TR><TD CLASS="quote">i assume you have an h series block. they dont have the crankcase ports on the back of the block like B series have....if that's what you were thinking. The best thing to do for a return is to make another bung in your oil pan to drain the can into.</TD></TR></TABLE>
exactly what i was asking. thank you! i wonder if i can just use the oil dran already in the pan and put i fitting in there, or fab up a little double fitting. thanks
honda4lyfe91
Apr 11, 2014 05:31 PM
nrraiders35
May 16, 2013 12:00 PM
laziebun
Dec 15, 2008 07:56 PM
h22 civic
Oct 29, 2005 06:40 PM
black_sh
Aug 24, 2003 12:25 PM
