Heating up?
Old Sep 15, 2007 | 08:45 PM
Thatssojdm's Avatar
Default Heating up?
I have a 93 honda prelude with a jdm h22a i just got it back from the shop for over heating too much and kno it just barely heats up one bar above, as soon as i turn on the heat it goes down. im gonna try this product in my anti freeze that lowers the temp 16%, is there any thing that i could do?
Old Sep 15, 2007 | 08:48 PM
preludefien
Guest
Posts: n/a
Default Re: Heating up? (Thatssojdm)
umm that **** is wierd..is you sender unit hooked up right. i know if its not hooked up and touching something it will be all over the place
Old Sep 15, 2007 | 08:50 PM
Hawkze_2.3's Avatar
See if your fans are working, check the engine and ECU grounds, check the thermostat, bleed the cooling system, etc...
Old Sep 15, 2007 | 08:54 PM
Thatssojdm's Avatar
Default Re: Heating up? (preludefien)
I believe that it is, so ur saying that cooliing stuff in ur anti freeze is weird? another thing is that as soon as i turn the engine of from reading a little hot and turn it back on its back to normal...
Old Sep 15, 2007 | 08:56 PM
Thatssojdm's Avatar
Default Re: Heating up? (Hawkze_2.3)
my fans are working my ecu seems fine, i just got the damn thing back today and it was running perfect the fans would come on even with out the key in it as normal but now they dont come on after i take off the key..
Old Sep 15, 2007 | 09:29 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thatssojdm &raquo;</TD></TR><TR><TD CLASS="quote">my fans are working my ecu seems fine, i just got the damn thing back today and it was running perfect the fans would come on even with out the key in it as normal but now they dont come on after i take off the key..</TD></TR></TABLE>
Ok, I'm sure the ECU is fine, but bad/loose grounds can cause the temp gauge to act wierd.
Old Sep 15, 2007 | 09:35 PM
Thatssojdm's Avatar
ok i will test all of my connection tomorrow
Old Sep 15, 2007 | 10:29 PM
Hawkze_2.3's Avatar
There's a main ECU ground right on the underside of the thermostat housing (where the longer lower radiator hose goes into the engine), also check the tranny ground and valve cover ground. Basically just unbolt and sand down the mounting surfaces with fine sandpaper so the connection is good.
J2MB
Aug 5, 2015 06:25 PM
gabrielsousa
Oct 19, 2014 04:30 PM
91prelude4me
Jun 29, 2014 04:21 PM
h22a.jdm.lude
Nov 1, 2009 07:35 AM
ep3_greddy
Oct 2, 2007 08:04 PM
