would this be a good setup to go with?
Old Sep 12, 2007 | 05:40 PM
mikeaitken's Avatar
Default would this be a good setup to go with?
some place i was referred to. any good for boost? my fisrt really getting into building for one. thanks. plannin on walbro fuel pump and new injectors and all that too. but just curious if this would be a good setup to go with to build?
-ERL SuperDeck 1 Sleeves - Pressure tested at 45psi (closed deck)
-CP Pistons 9.0:1 compression
-Eagle Rods
-CP Piston rings, wrist pins, locks
-ACL Main/Rod Bearings and Thrust Washers
-OEM Honda Gaskets
-OEM Honda Oil Filter
-Block bored and final hone
-Block hot tanked 4x
-Align Hone
-Polished Crank
-Block resurfaced
-BluePrints
-Balance Shaft Removal Kit ??
PrecisionH23a
May 10, 2010 07:17 AM
be18see1
Aug 6, 2009 06:37 PM
DarkSol97
18
Aug 30, 2004 10:43 PM
Turbo-Honda
Dec 30, 2003 05:28 PM
sweet
Apr 21, 2003 06:57 AM
