Power window issue
Old Nov 26, 2007 | 01:29 PM
Inextricabledrvr's Avatar
Default Power window issue
My drivers side power window will not go up. I can hear the motor going, but the window doesnt follow.
Did it just fall off track? If so, is it hard to fix?
Anybody experience this?
Old Nov 26, 2007 | 02:48 PM
SnlpeR's Avatar
could be the missing teeth on the regulator
or the rubber bushing type thing on the window motor split apart
Old Nov 26, 2007 | 03:08 PM
Acidcrakker's Avatar
Default Re: (SnlpeR)
My passenger side window gets stuck, but I can usally push it back up.
Old Nov 26, 2007 | 09:11 PM
dudeitsahonda's Avatar
can u push it up ?
does it not work at a certain range?
i had broken/grinded down teeth b4 . changing it was no problem
Old Nov 27, 2007 | 07:53 AM
Dicorp's Avatar
Default Re: (dudeitsahonda)
exact same thing happened to me last week, where can i get replacement teeth?
Old Nov 27, 2007 | 08:05 AM
Hawkze_2.3's Avatar
Default Re: Power window issue (Inextricabledrvr)
Just take off the door panel (carefully) and you will be able to see all the window stuff...should be easy to see what happened if you do that.
Old Nov 27, 2007 | 08:34 AM
Dicorp's Avatar
Default Re: Power window issue (Hawkze_2.3)
i did, and i remove the regulator assembly. the teeth are worn down on the motor. could i just replace the cog(gear) or do i need the whole new assembly?
Old Nov 27, 2007 | 08:47 AM
Hawkze_2.3's Avatar
Default Re: Power window issue (Dicorp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dicorp &raquo;</TD></TR><TR><TD CLASS="quote">i did, and i remove the regulator assembly. the teeth are worn down on the motor. could i just replace the cog(gear) or do i need the whole new assembly?</TD></TR></TABLE>
I mean the OP should take off his door panel, but oh well It looks like you would probably have to order the whole motor:
http://www.hondaautomotivepart...INDOW
Old Nov 27, 2007 | 10:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudeitsahonda &raquo;</TD></TR><TR><TD CLASS="quote">can u push it up ?
i had broken/grinded down teeth b4 . changing it was no problem</TD></TR></TABLE>
I can push the window up and down without any real resistance. The window will not function using the button what so ever.
I took it apart last night and I tried to line up the teeth again with the regulator I am assuming and it tried to go up, but it wasnt grabbing correctly.
Is it expensive to replace this part?
Old Nov 27, 2007 | 02:20 PM
SnlpeR's Avatar
does the gear on the motor spin when you try to roll up/down the window?
Old Nov 27, 2007 | 09:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">does the gear on the motor spin when you try to roll up/down the window?
Yes the motor spins. It seems like its not grabbing anymore. I tried to align it back with the teeth, but no luck.
Old Jan 31, 2008 | 04:48 AM
mihasik's Avatar
My power window doesn't work but i could here the motor i thought the regulator assembly is faulty i got another one the doesn't work either so i been told that it s a switch problem i got a switch still nothing. what could be wrong please help!!!!!
Old Jan 31, 2008 | 06:43 AM
Infinity_Racer's Avatar
Default Re: Power window issue (mihasik)
same thing happened to my civic's pass side and the window had fallen off of the track...just put on back on the track and worked good....i think my passenger slammed my door too hard or something
djfob
May 8, 2006 02:09 PM
full Circling
Jul 6, 2005 07:56 AM
EX-T
Dec 2, 2003 03:53 PM
Gennady
Jun 18, 2002 05:23 PM
