Bad steering return
Old Dec 3, 2007 | 09:24 AM
underbelly's Avatar
Default Bad steering return
As the topic states. I turn my wheel to the right makeing a right hand turn, and I have to almost manually turn wheel to center. When I make left hand turn, wheel automatically goes to center after turn with hardly no help.
What gives. Bad Bushings? Bad rack? Both? i have 240K miles
Also on very cold days when i start car the wheel will automatically turn all the way to left, and cant center wheel untill car warms up. hell you cant even turn it from full left
Old Dec 3, 2007 | 09:34 AM
Hawkze_2.3's Avatar
Default Re: Bad steering return (underbelly)
What dictates how fast/slow your wheel returns to center is caster. It's one of the 3 things they do when you get an aligment.
I would go to an alignment place and get your caster checked out. You could have bad radius rod bushings....
Old Dec 3, 2007 | 09:55 AM
mgags7's Avatar
Well the fact that the steering locks left while the fluid is cold suggests to me that there's a problem in the valve body or maybe a clogged line actually inside the rack.
underbelly's Avatar
What are all the components that effect caster?
Old Dec 3, 2007 | 09:59 AM
underbelly's Avatar
Default Re: (mgags7)
Is the valve body replaceable? I dont think the power steering fluid has ever been flushed
Old Dec 3, 2007 | 10:01 AM
Hawkze_2.3's Avatar
Default Re: (underbelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underbelly &raquo;</TD></TR><TR><TD CLASS="quote">What are all the components that effect caster?</TD></TR></TABLE>
The arm and bushings in the lower left:
Could also be the rack like mgags7 said. Probably a clog or buildup in there if it is the rack.
Old Dec 3, 2007 | 10:15 AM
underbelly's Avatar
On a side note. Whats the best way to change the power steering fluid?
Old Dec 3, 2007 | 10:27 AM
mgags7's Avatar
The helms way.
Basically, you take off a line and start the engine, and let it pump out the fluid for you. It doesn't get <u>everything</u> but it is good enough for most.
Old Dec 3, 2007 | 03:07 PM
Giant_Bean's Avatar
I remember reading about a TSB for this, I think it was related to the PS pump, Ill see if I can find it again.
Found it, but it's not related to your problem:
http://consumerguideauto.howst...2.htm
Modified by Giant_Bean at 7:44 PM 12/3/2007
crazyhorse2011
43
Dec 18, 2017 05:27 AM
swizz977
24
Jan 20, 2014 12:05 PM
Jer'rome
Mar 4, 2013 02:57 PM
the-one1
Jan 17, 2005 06:54 PM
MenaceAccord92
Oct 22, 2004 06:41 AM
