oil in knock sensor plug
Old Dec 3, 2007 | 07:48 AM
Apex1972's Avatar
Default oil in knock sensor plug
I recently replaced my knock sensor. It ran for about a week without a CEL. Then it threw code 23 again. Me and SleepyH22 were looking at the connector and it was completely soaked in oil. I took some sillicone spray and cleaned it out real good. So far the light has not come back. Would the oil cause a bad connection, also where could the oil have been coming from. I know the knock sensor is above the oil filter, but how could it be this covered i oil???
Old Dec 3, 2007 | 07:53 AM
mgags7's Avatar
You could have a leaky head gasket dripping down onto it.
...or you could have a hole in the oil filter spraying oil....lol I've actually seen that happen before....
Old Dec 3, 2007 | 12:14 PM
Apex1972's Avatar
Default Re: (mgags7)
Thanks for the speedy reply. SleepyH22 also said the head gasket may be leaking. I did not know it could leak like that and not cause more severe problems. What else would you suggest be done to a motor while the headgasket is being replaced. Motor has probably 80-90 thousand miles. Just did a new timing belt and water pump about 4 months ago.
Old Dec 3, 2007 | 12:21 PM
mgags7's Avatar
How about getting down there and figuring out where the oil leak is coming from first.....
Old Dec 3, 2007 | 02:03 PM
Apex1972's Avatar
Well, it is definately not from under the knock sensor, because we also replaced the oil pan gasket as well as the oil filter housing O ring. I figure the headgasket is the only thing left.
Jay0016
Jan 9, 2011 11:56 AM
Japankid
Welding / Fabrication
Apr 9, 2009 12:35 PM
JDM SIR-G
Jan 22, 2009 06:06 PM
Attaus
Jan 4, 2007 08:26 AM
Jdmglenn
Jan 12, 2005 07:51 PM
