more tranny problems
Old Nov 21, 2007 | 11:33 PM
alex_belarus's Avatar
Default more tranny problems
ok here is the thing, about 2 days ago i posted about my reverse not working, now while i was pulling of today my first gear grinded and i had to start of in second, and while i was trying to shift into 5th it grinded and wouldnt stay in place, i pulled over to the side and tried to put my gear into 5th without driving off and just wouldnt stay in place and kept popping out, and as for my reverse it just doesn't work at all i cant even get it in its just blocked, is there anyone on here that has ran into this problem before? and does anyone know how i can get this fixed also my gears just don't feel the same anymore as i shift could it possibly be transmission oil? and it is a 1999 sh thank you very much in advance
Old Nov 21, 2007 | 11:56 PM
someone help me please, would it be possible that my tranny got scraped a little bit on speed bumps cause my car is really low to the floor and some of the fluid ran out?
Old Nov 22, 2007 | 12:02 AM
93sivtec's Avatar
Find out whats leaking....jack up your car and inspect the tranny.Try filling it with fluid and going through the gears to see if it helps,if not take it to a tranny shop for inspection.Good luck
Old Nov 22, 2007 | 12:07 AM
kk thx cause its only been like this for about past 3 days, first reverse about 2 days ago and now these 2 gears, and i found some oil on my doors today and sideskirt could that be it?
Old Nov 22, 2007 | 05:42 AM
gogunkergorilla's Avatar
Default Re: (alex_belarus)
Your probably running low on oil if its popping out of gear. Check if there is oil leaking out of the seals.
Old Nov 22, 2007 | 05:52 AM
jaywoodz's Avatar
Default Re: (gogunkergorilla)
been there, done that, no fluid.
Old Nov 22, 2007 | 06:57 AM
Burgiop's Avatar
if the tranny is full of fluid, its time for a new one!
Old Nov 22, 2007 | 01:40 PM
well i did find a lot of oil oh my side skirt and the lower door as well as little bit on the tires, so im gonna go check my fluids thx everyone
elly7b
Dec 4, 2013 09:52 PM
Mr. TopFuel
Feb 28, 2008 09:12 PM
str8JDMteggy
Jul 27, 2006 09:25 PM
SonicRacing
Feb 7, 2006 02:49 PM
HeikDiesel
Nov 19, 2002 11:53 AM
