quick ecu question
Old Nov 21, 2007 | 06:40 PM
xxmastermindxx's Avatar
Default quick ecu question
I'm finishing up my f22/h23 and I want to make sure that I'm using the correct stock ecu. I'll upgrade for tuning in the spring when I get a turbo kit together, but for now, all stock.
Now, is it ok to use the p14 H23 ecu, since the F22 bottom has the H23 dohc head? After doing a little googling, I found a list that says a stock F22 ecu is a P0A obd0? Not familiar with that at all.
thanks
Modified by xxmastermindxx at 4:09 PM 11/22/2007
Old Nov 22, 2007 | 01:09 PM
Default Re: quick ecu question (xxmastermindxx)
up
Old Nov 22, 2007 | 03:03 PM
SikB's Avatar
If you are using the stock h23 intake manifold then it would be better to use the p14 since it would control the iabv. Also I think the h23 fuel map would be better than the f22 one but I can't say for certain. I don't know of any other issues that you would have. To my knowledge the f22 doesn't have any more sensors than the h23.
Old Nov 22, 2007 | 05:27 PM
Default Re: quick ecu question (SikB)
thanks
well i know i'd probably throw a code because the F22 doesn't have a KS, but i'm going to do what a few guys on here said, install the KS at the alternator bracket temporarily until i upgrade my ecu/tuning option.
scobaru
Mar 2, 2011 12:24 PM
scobaru
Mar 2, 2011 12:23 PM
SlammedCD7
Aug 11, 2004 06:18 PM
