H22a4 compression for FI
Old Nov 30, 2007 | 06:03 PM
Lunchbox88's Avatar
Default H22a4 compression for FI
I just did a compression test on my 97(base) prelude with the h22a4. The readings came out as 180,175,175,175. My question is, is this a good enough compression to safely run a turbo at 7psi. And its all stock internals right now. I believe the honda says the nominal compression is 185, is this correct?
Old Nov 30, 2007 | 10:17 PM
Lunchbox88's Avatar
Default Re: H22a4 compression for FI (Lunchbox88)
bump
Old Nov 30, 2007 | 10:18 PM
Hawkze_2.3's Avatar
That's good compression, but there's a lot of other things to consider if you're going to turbo a car that was not meant to be boosted.
Old Nov 30, 2007 | 10:27 PM
PrecisionH23a's Avatar
Start reading
https://honda-tech.com/zerothread?id=316373
https://honda-tech.com/zerothread?id=783372
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
Spectrum24x
Jan 15, 2006 05:08 PM
H2nr
Nov 12, 2004 09:45 AM
