Crank Angle Sensor
Old Nov 28, 2007 | 06:51 PM
kornerk12's Avatar
Default Crank Angle Sensor
Im getting a code for crank angle sensor. What are the possible problems and or solutions ? What does this exactly mean ?
Old Nov 28, 2007 | 08:58 PM
gotjnco's Avatar
Default Re: Crank Angle Sensor (kornerk12)
i need help with this too, i cant find it in the helms manual, but my friend's 96 bb1 with a jdm h22a though he is obdII has this problem, i bought him the sensor, but I dont know where is the location of the sensor to fix the issue
Old Nov 28, 2007 | 09:02 PM
M2B4's Avatar
Default Re: Crank Angle Sensor (gotjnco)
if its obd1 in in the distributor. replace that. last time I washed my bay i got water in there and i threw that code. new dist. and good to go.
edit: not sure but I think the obd2 is located near the oil pump
Old Nov 29, 2007 | 04:03 AM
mgags7's Avatar
The 92-95 has the sensors in the distributor.
96+ has the TDC and CKP sensors at the oil pump, and the CYP in the distributor still.
If you put an obd1 engine in an obd2 car, you need to swap on the obd2 oil pump/distributor and sensors and all, or wire the obd1 crap to work and use that distributor.
Old Nov 29, 2007 | 08:36 PM
kornerk12's Avatar
Default Re: (mgags7)
im obd2.
Old Nov 30, 2007 | 04:58 AM
92hondalude's Avatar
Default Re: (kornerk12)
then change out the sensors on the oil pump. Take off the crank pully and the timming belt cover, i think you might have to take the timming belt off also.
akinas-crx
Oct 28, 2011 06:00 PM
B16CRXT
Mar 5, 2008 09:40 AM
Mudlocked
Jul 31, 2007 03:24 PM
93slmdcvcsi
Feb 6, 2006 08:45 PM
therealnapster
Aug 24, 2001 06:47 PM
