Difference in H22a1 and H22a?
Old 11-26-2007, 05:35 PM
All Mighty's Avatar
Default Difference in H22a1 and H22a?
Hey all. I tried searching but to no result. I am rebuilding my H22a. Can I use USDM H22a1 parts? Or do i have to use straight JDM H22a parts such as rings, bearings etc etc? I know H22's have two different pistons in it and all that. Just wondering if I can use USDM H22 parts instead of paying a **** ton for JDM parts.
Thanks guys
All Mighty is offline
Old 11-26-2007, 05:45 PM
95greenlude's Avatar
Default Re: Difference in H22a1 and H22a? (All Mighty)
yes, h22 and h22a1's parts are interchangable
95greenlude is offline
Old 11-26-2007, 05:49 PM
All Mighty's Avatar
Default Re: Difference in H22a1 and H22a? (95greenlude)
even internal wise? Can I still use H22a1 rings, bearings, and everything on a JDM H22a? That would save me alot of money
Old 11-26-2007, 05:53 PM
i'm not 100% sure, but i believe they can be
Old 11-26-2007, 05:54 PM
Moderator
snobordboy's Avatar
Yeah the only difference should be piston height, even your rings should be the same, and obviosuly make sure you hone to spec and set ring gap properly.
snobordboy is offline
Old 11-27-2007, 02:54 AM
All Mighty's Avatar
Thanks guys. I will be tearing it down within two weeks. So lets hope H22a1 parts match H22a
Old 11-27-2007, 05:28 AM
Si Speed's Avatar
Default Re: (snobordboi)
Right. Piston height is the only difference. I've heard the cams are slightly different and heard they're the same but I'm not sure. Never had any to compare myself.
Si Speed is offline
Old 11-27-2007, 07:10 AM
Televator's Avatar
Default Re: (All Mighty)
Do you know what year your H22A is? 98+ will have larger mains than an H22A1. Although, you may not need to worry if you are just swapping pistons and rods.
Televator is offline
Old 11-27-2007, 08:43 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the only difference should be piston height, even your rings should be the same, and obviosuly make sure you hone to spec and set ring gap properly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Speed &raquo;</TD></TR><TR><TD CLASS="quote">Right. Piston height is the only difference. I've heard the cams are slightly different and heard they're the same but I'm not sure. Never had any to compare myself. </TD></TR></TABLE>
Piston height?
You mean compression height?
If so, you're wrong.
The difference is the displacement of the dome. (jdm are 1.7cc IIRC)
mgags7 is offline
Old 11-27-2007, 06:01 PM
All Mighty's Avatar
Default Re: (Televator)
The H22a is pre 98.
Old 11-27-2007, 06:02 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Mighty &raquo;</TD></TR><TR><TD CLASS="quote">The H22a is pre 98.</TD></TR></TABLE>
You're asking the questions. We're giving the answers.
mgags7 is offline
Old 11-27-2007, 06:18 PM
All Mighty's Avatar
haha I know I know. Should I just go ahead and buy H22a rings, bearings and such. Then stuff like full gasket set, oil pump, water pump etc etc be purchased for an H22a1 for cheaper?
nemesiskrp
09-12-2010 04:38 PM
h22sedan
08-21-2007 09:40 PM
d_SUPAl1l
11-13-2006 05:29 AM
domestic_rice
09-25-2005 12:32 PM
hundredfootstrip
10-02-2002 03:15 PM
Quick Reply: Difference in H22a1 and H22a?
  • Ask a Question
Question Title:
Description:
