fuel filter
Old Nov 22, 2007 | 07:39 PM
paniaguae640's Avatar
Default fuel filter
I have a 94 prelude si and would like to replace the fuel filter but I don't know where it is located. where would it be?
Old Nov 22, 2007 | 08:27 PM
honda3431's Avatar
Default Re: fuel filter (paniaguae640)
when looking at your engine, its up and to the left. just left of the intake manifold, bolted to the firewall. its a black cylinder with 2 hoses attached to the top. good luck replacing it, sometimes they don't want to come off. just be patient and don't bust the lines or anything. and make sure you relieve fuel pressure first.
Old Nov 22, 2007 | 09:48 PM
thanx
Old Nov 23, 2007 | 07:44 AM
AmauryR's Avatar
Default Re: fuel filter (honda3431)
anybody have a tough time with the hardline fitting? I tried doing mine before and can't even get good leverage (with flare nut wrench). Someone mentioned before using crows feet + a ratchet but I don't want to chance stripping it. Everything on my car seemed to have been bolted down with a 3/4" impact gun
-l8r
Old Nov 23, 2007 | 11:52 AM
same here, I would like to know without stripping it. It's been tough trying to change it.
Old Nov 23, 2007 | 04:51 PM
skinnyboy's Avatar
oh boy, done mine yesterday, the 17mm banjo bolt was a **** to get off, the 14mm IN line was a bastard too. Just use flare nut spanners, i found my regular Flank Drives trying to ride up with the torque applied in getting them to budge.
Old Nov 23, 2007 | 05:41 PM
baselude's Avatar
break them lose before you do the mount for the filter =P i made that mistake
Old Nov 25, 2007 | 11:19 AM
MatrixGSR's Avatar
Default Re: fuel filter (baselude)
There's also a 19mm nut on the top of the fuel filter you can get a hold of... The best way is to have a friend hold that still while you're taking the flare nut off.
Keeps it from bending that top bracket. I know thats a common issue.
my Efin SI
Apr 16, 2010 09:24 AM
redlinez_r_us
Sep 16, 2009 12:02 PM
handa
Apr 3, 2005 03:27 PM
brody
Aug 15, 2002 12:52 AM
AK94GSR
Aug 7, 2002 08:02 PM
