Power Steering removal....
Old Nov 22, 2007 | 03:05 PM
lude98SH's Avatar
Default Power Steering removal....
I did this awhile ago and have had no regrets. I originally threw a code, im guessing it maybe had something to do with the power steering pressure switch but never actually checked it because it went away. I used the line loop method and have had no problems with the rack. From what it seems it has been said to " loop the lines and fill them with fluid to lube the seals in the rack". However if you were to block off those holes with caps (basically just to keep out dirt) and make sure mostly all the fluid is out of there, would it damage anything ? Because is that section of the rack even needed anymore ? Or do you still need that lubrication in there ? I have been told otherwise by some people that is why I ask, I always thought that you needed to atleast of it looped or do the manual rack conversion.
Old Nov 23, 2007 | 06:41 AM
mgags7's Avatar
If you had taken a second to read the manual conversion writeup, you'd have seen that you must lubricate the inside of the rack well. Use synthetic grease and try get out as much of the PS fluid as you can.
Old Nov 23, 2007 | 06:43 AM
117's Avatar
117
If you don't use any lube, the piston o-ring will cause a bit of drag. Best thing to do is to disassemble the rack, remove the piston o-ring, then use some high pressure grease on everything to keep the rack operating smoothly. That's what I did 3 years ago, and no problems have shown up yet.
Old Nov 23, 2007 | 06:45 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (117)
i used some fittings from home depot and a spare clutch master cylinder resevoir
the middle is the ps
Old Nov 24, 2007 | 11:25 AM
lude98SH's Avatar
Default Re: (mgags7)
i have read it many times. I just was told this by SOMEONE ELSE and wanted some reassurance that I was right about the whole matter.
Old Nov 24, 2007 | 11:30 AM
Hawkze_2.3's Avatar
Default Re: Power Steering removal.... (lude98SH)
Yeah, I don't think you would want a dry rack for long. If you drain the fluid and cover the holes you will have a little fluid, but I would think it would start to settle to the bottom before too long and then your rack would start to wear. Either keep enough fluid in there with a breather or take it apart and grease it up.
bizzle2288
Aug 27, 2012 05:29 PM
Hondaphile13
11
Jul 12, 2009 06:39 PM
allhonda
Feb 11, 2009 04:30 PM
all stock
15
Feb 18, 2003 12:32 AM
Beave0101
Nov 24, 2002 07:23 PM
