valve lash problem..
Old Jun 2, 2009 | 10:57 AM
efsihatch91's Avatar
Default valve lash problem..
got a 92 prelude with h23. ran good with a tick so i adjusted the valve lash now no tick motor sounds good except at idle it putts. when i press the gas it sounds good only when it idles it putts. ne ideas?
Old Jun 2, 2009 | 11:01 AM
ben_deez's Avatar
Default Re: valve lash problem..
what if you re-adjusted your ignition timing and idle..
(by the numbers)
thats what I had to do when I adjusted my valves..
Old Jun 2, 2009 | 01:24 PM
ok ill have to try that.
Old Jun 2, 2009 | 01:28 PM
Acidcrakker's Avatar
It may be possible that you have set the leash too tight. It could be choking itself at low idle
Old Jun 2, 2009 | 02:56 PM
ok i have it figured out. they were too tight and the dizzy was all the way advanced for some reason. the feeler gauge i used the first time was too old and worn so it was inaccurate i bought a new one re adjusted the valves and timeing and now its good thanks for the help guys
Old Jun 2, 2009 | 02:59 PM
vinuneuro's Avatar
And make sure to adjust them when the motor in completely cold.
Old Jun 2, 2009 | 03:20 PM
ben_deez's Avatar
i'll sqeeze one last post in here......
if you ever get a chance, you should try go-no-go feeler gauges......I used them this last time and I gotta say, It made a difference
Old Jun 2, 2009 | 10:26 PM
MikeLuder's Avatar
make sure lash is set 'completely cold' like 3 hours or overnight...
you set some valves or all of them too tight
need to make sure that they are all the same, so after you do each valve, check & recheck the clearances to be sure that they stayed what you set.
You want 6' intake & 8' exhaust
Old Jun 3, 2009 | 09:06 AM
ive got them pretty good now cars running good with no ticks anymore. i think i did have them too tight due to a old worn feeler gague was giving me wrong readings. thanks for all the help.
Cole Peters
Feb 25, 2015 06:48 PM
DaYZeD.1
Apr 19, 2008 03:07 PM
JasonST
Nov 24, 2007 05:05 PM
4gen
Dec 7, 2003 09:35 AM
