Suspension problem?? Help
Old May 21, 2009 | 07:29 PM
MRBOOMBASTIC's Avatar
Default Suspension problem?? Help
when i drive on bumpy road it gives a squeeky sound from right rear. dont know what is it. any suggestions what should i check on?
Old May 21, 2009 | 07:32 PM
teambk8's Avatar
Default Re: Suspension problem?? Help
LCA bushings? bad strut? Have you jacked the car up and given it a once over? Look first, then post for help otherwise you could have anything from a bad bushing to a squirrel that gets scared it will fall off when you hit bumps and squeaks.
Old May 21, 2009 | 07:34 PM
checked that it was fine.
Old May 21, 2009 | 07:38 PM
SKO's Avatar
SKO
check the TSBs most of the common sqeeks and things are in there.
Old May 21, 2009 | 10:27 PM
gstrudler's Avatar
I have it too in my '97, just haven't gotten around to fixing it yet. I know the shock collar was one of the TSB's. What year/model are you?
Old May 21, 2009 | 11:14 PM
slimjimming6688's Avatar
sprey wd40 on things and see if it changes
jdmej814
Suspension & Brakes
Sep 17, 2010 01:11 AM
jdmej814
Aug 30, 2010 06:22 PM
BigChris
May 10, 2004 10:22 AM
95srv
Apr 23, 2004 07:32 AM
.(Lazarus).
Jan 25, 2003 12:32 PM
