map sensor problem
Old May 30, 2009 | 01:43 PM
BrizzlEK's Avatar
Default map sensor problem
ok my car idles funny, at somepoint the car will dope severely and than rev up, if i disconnect the vaccum line to the map sensor it stops it, so i figured the map sensor is bad or going bad, the old style map sensors are mounted on the firewall and are quite expensive compared to the throttle body map's, i have read that you can convert it but have never seen any follow up, can anyone please help me.
i know obdII maps are tb and obdI are fire wall mounted.
Thanks,
Brent
Old May 30, 2009 | 05:52 PM
Hawkze_2.3's Avatar
Default Re: map sensor problem
First I would test it to find out for sure it is the MAP sensor.
Then just look for one at a junkyard, eBay, or forum classifieds. I think I have a few sitting around in the garage also.....
Old May 31, 2009 | 11:29 AM
BrizzlEK's Avatar
how do i test it? like i said before disconnecting the vac line to the sensor fixes the idle. or is there something else related to it?
Old May 31, 2009 | 12:41 PM
Hawkze_2.3's Avatar
Well, officially you would want to follow the procedure in the Helms manual, but it does sound like it could be your problem.
Old May 31, 2009 | 05:04 PM
BrizzlEK's Avatar
how, or where do i find a helms manual?
Old May 31, 2009 | 06:28 PM
Hawkze_2.3's Avatar
You can buy one online (very good investment) from helminc.com or eBay, or you can download them for free on a number of sites. An actual book is much more helpful than a computer file, though....
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
CodyGt3076r
Feb 7, 2014 06:35 PM
fenix4o9
14
Jan 30, 2013 12:39 AM
ALL MOTOR DA
Jun 8, 2006 05:58 PM
agratise
Feb 24, 2005 05:48 AM
