CEL
Old Mar 14, 2010 | 08:22 PM
98BBSiCxs's Avatar
Default CEL
i bought a JDM H22a and switch the ecu because the car needs inspection. drove around a little and now i have a CEL but when it passes like 5k rpm it starts to Flash. checked the codes and its throwing Random Misfire in all 4 cylinder.
anybody ever ran into this problem??
Old Mar 15, 2010 | 08:23 PM
98BBSiCxs's Avatar
Default Re: CEL
nobody has nvr ran into this problem?
Old Mar 16, 2010 | 05:39 AM
BHC's Avatar
BHC
Default Re: CEL
Maybe an issue with coils? Or check all wire connection if this happened right after the swap.
Old Mar 18, 2010 | 10:34 AM
98BBSiCxs's Avatar
Default Re: CEL
ive had a few suggestions. so ive Changed Spark plugs and wires. cleaned EGR Valve and CEL still on.
Old Mar 18, 2010 | 10:49 AM
92civlude's Avatar
Default Re: CEL
Did you clear the ecu codes after the repairs?
Old Mar 19, 2010 | 08:02 PM
98BBSiCxs's Avatar
Default Re: CEL
yea. after each repairs i take the battery cable out for like a min than hook it back up
Old Mar 20, 2010 | 08:08 AM
92civlude's Avatar
Default Re: CEL
If the light comes when you start the engine, there is a good chance the codes didnt clear. And may have already fixed the car. But if the light comes on after the engine hits high rpm, I would look into more secondary ignition as the fault. Cap, rotor, coil perhaps?
honda_aus87
Mar 26, 2011 08:01 PM
Track Beast
Dec 5, 2010 01:04 PM
Mr.Death
Sep 16, 2007 02:05 PM
95LSS
Mar 7, 2004 11:00 AM
RineRacing
Apr 14, 2003 05:53 AM
