Vtec Wiring Help
Old Mar 18, 2010 | 05:21 PM
gorthjr's Avatar
Icon2 Vtec Wiring Help
ok i have another problem, i am just about to start wiring my vtec, and i have 2 vtec solenoids or whatever, but one doesnt have a bottom plug because its capped off with a bolt.
do i need to use this bottom plug or can i just go about my wiring without it, and i used my si harness so i dont have a plug to match up with it.
Old Mar 18, 2010 | 05:42 PM
gorthjr's Avatar
Default Re: Vtec Wiring Help
any help plz?
Old Mar 18, 2010 | 06:08 PM
Kane666's Avatar
the green plug is for oil pressure at 55psi. if you have a usdm ecu you have to use that one. the other is off a jdm h22 that doesnt use that sensor.
Old Mar 18, 2010 | 07:10 PM
gorthjr's Avatar
i got a p13 ecu, not sure if its jdm or usdm
Old Mar 18, 2010 | 10:05 PM
Kane666's Avatar
plug in the jdm one. if that gives you a code use the other one. you can switch the tops ok if you dont want to cut anything to hook to that cut wire on your usdm. if you switch the tops you might as well clean the thing out so it works 100% and get any old oil out of there.
sh!ft
Sep 1, 2009 07:03 PM
Slo_RSX
Nov 6, 2008 06:04 PM
mcgee*
Jun 4, 2006 11:57 AM
phatrick2332
Aug 28, 2003 06:28 AM
SLOW4drINTEG
May 5, 2003 10:47 PM
