HELP!!!!! OBD2 to OBD1 Distributor
Old Mar 15, 2010 | 05:10 AM
myhatch98's Avatar
Default HELP!!!!! OBD2 to OBD1 Distributor
Here is the issue i have swapped an obd1 h22 into an obd2 prelude. i have done a bunch of research and no one has a strait answer. everything is done and no spark. i do not want to replace the oil pump so please do not give me that solution. i was told you can wire the sensors that are suppose to go to the oil pump to an obd1 distributor. i have an external coil. please someone give me that answer to this issue. i need the wiring colors to convert it from obd2 to obd1 on the distruter. i have 4 wires from distribuer and 4 wires from crank sensor
thanks in advance
Old Mar 15, 2010 | 07:58 AM
myhatch98's Avatar
Default Re: HELP!!!!! OBD2 to OBD1 Distributor
i know someone has to have the answer to this?? i am also changing it to internal coil as well. i have looked on FAQ but it looks like the link is no good
Old Mar 15, 2010 | 05:14 PM
97H22AEK's Avatar
OBD1 ECU (engine computer)
blue/green ckp signal
blue/yellow ckp ground
orange/blue tdc signal
white/blue tdc ground
orange cyp signal
white cyp ground
blue "speed output"
black/yellow "ignition input"
all above on connector "B" on ECU P-13 OBD1 (16 slot grey plug pins half empty)
96-98 Civic OBD2 Car Harness
(some colors may be different on prelude?) connector "C" (36 slot blue plug pins half empty)
blue CKP signal
white CKP ground
green TDC signal
red TDC ground
yellow CYP signal
black CYP ground
blue/white "vehicle speed sensor"
Grey Connector "A" (39 slot plug pins half empty)
Old Mar 15, 2010 | 05:19 PM
HondaPartsHero's Avatar
Technical Hero
Old Sep 30, 2020 | 04:59 PM
1turbotegplease's Avatar
is the obd2b picture backwards? My plug has the dead input on the opposite side of the bottom???
in fact so does the obd1 plug i have they are both backwards in the picture?
Old Sep 30, 2020 | 05:02 PM
Accordian47's Avatar
10 Year Member
What end of the connector are you looking at? It says on the table/diagram "All Plugs Are Shown From Wired Side"
Old Sep 30, 2020 | 05:04 PM
ohhh forsure so in the picture its looking through the pin side? That would make a lot more sense.
10
Sep 24, 2012 05:30 PM
despat
Apr 2, 2010 02:56 PM
Cyphear
Jul 13, 2007 03:58 PM
stockCRXsi
Jun 8, 2007 05:28 PM
mtber
Jul 14, 2003 08:05 PM
