bogging before vtec
Old Mar 30, 2010 | 10:30 AM
ksay817's Avatar
Default bogging before vtec
this has been an on and off problem for awhile now... the problem is that right before i hit vtec the car jus boggs for a second like its misfiring and then vtec will kick in but this only happens when the car has a half tank of gas. after i put a full tank of gas in the problem goes away anyone got an idea of what the problem is? i own a h22a prelude if that helps any.
Old Mar 30, 2010 | 05:24 PM
Acidcrakker's Avatar
Default Re: bogging before vtec
This happens to me at random times. ESP when I run at the track. I checked it out, turned out that the coil wire(cheapo autozone) was to close to some ground wires cause a distortion in the wires. Moving it away from other wires fixed it.
Old Mar 30, 2010 | 06:31 PM
SOHC_4dr's Avatar
its kind of a tough call, do you happen to have any mods or tuning done to it? does it only happen at half tank or at half and below?
Old Mar 31, 2010 | 05:47 AM
ksay817's Avatar
it happens at half a tank and below and it only has a remapped ecu but this problem never happened. it jus started having this problem. and (acidcrakker) what coil wire are u talking about? a pic of where its located and where it was touching would help me alot. thx
yeng_vaj85
Oct 2, 2009 10:26 PM
jvonb
Jun 14, 2006 07:20 PM
Got Milk
Dec 30, 2005 08:13 AM
