having clutch issues
Old Apr 12, 2010 | 12:02 PM
swiftsmiles's Avatar
Default having clutch issues
So I replaced my clutch everything went well on putting it back together. But now the car doesn't go into gear? I didn't move the shift link when I took it apart I left everything in place so it should line up just fine. I even put the car into gear manual so I know it was in gear started it and it still didn't move. The only thing I can really think of is the flywheel because I didn't replace that. I really don't know can anyone help me?
Old Apr 12, 2010 | 12:21 PM
jordan_rael_420's Avatar
Default Re: having clutch issues
did u make sure when u installed the clutch u put it in right, on an oem clutch it says "flywheel side", did u make sure it was facing the right way when u installed it.also i know i shouldnt cheap out but i didnt get the flywheel resurfaced when i did mine and works fine.
Old Apr 12, 2010 | 06:04 PM
dtownrex's Avatar
did you install the throw out bearing?
eg6 type-R
Apr 9, 2012 06:19 AM
HS2G
Aug 22, 2004 08:45 PM
preluder
Jun 24, 2003 07:00 AM
OneThirtyEight
Jul 5, 2001 08:18 AM
