Random revving
Old Mar 20, 2010 | 10:52 PM
woodj87's Avatar
Default Random revving
My prelude has developed a problem over the last year or so that has become annoying. At first when the weather turned cold, the card would start revving at idle. It would alternate anywhere between 500 and 2000 until i starting moving. when i stopped again, it started again. a mechanic friend of mine tightened a bolt just below the throttle plate. he said that this spring loaded screw would back out from time to time causing this. He put some locktight on the screw and set it in a few turns. it worked for a time. then when the weather changed again, the problem returned. I'm not sure what is happening. any ideas?
Old Mar 21, 2010 | 05:03 AM
darkestfenix's Avatar
Default Re: Random revving
IAC valve
Old Mar 21, 2010 | 12:09 PM
woodj87's Avatar
thanks
Old Mar 21, 2010 | 12:23 PM
scribble912's Avatar
Would have to second that, look around online they have a way you can test that with a multi meter
n0thin_2z_here
Apr 16, 2013 09:08 AM
91EX4dr
Dec 6, 2008 06:30 PM
Kyles ej1
10
Jun 11, 2006 02:36 PM
TurnerDv1
Jul 27, 2003 12:37 PM
