'93 'lude error coding help
Old Mar 22, 2010 | 05:12 PM
06RSXbase1's Avatar
Icon6 '93 'lude error coding help
'93 SI H23, rich off the fuel map
coding 1 for 02 sensor
tried 2 diff a/m and then a known good oem 02 sensor, still coded
swapped stock ECU - P14 A11 MT for a
"known good one" purchased online P14 A10 MT from a '92 lude
Still codes 1
Any ideas????????
Thanks!!!!
Old Mar 23, 2010 | 03:06 PM
06RSXbase1's Avatar
Default Re: '93 'lude error coding help
Anyone? Need help!
Thanks!!!!!!
Old Mar 23, 2010 | 04:10 PM
Kronn 98SH's Avatar
My best suggestion would be to follow the instructions outlined in the service manual.
Old Mar 23, 2010 | 04:55 PM
06RSXbase1's Avatar
thanks for the suggestion - been there done that
all there is in the manual is the ECU, 02 sensor
and a WHT wire and a GRN/WHT connector wires
thought maybe someone had run into this and knew
if maybe these 02 connectors fail and need to be jumpered
or if they tend to break down in the harness somewhere
so you have to run new wires
randol_8o8
Engine Management and Tuning
Jan 7, 2017 01:26 PM
93blulude
Jul 4, 2008 05:02 AM
CRXified
35
Dec 29, 2005 07:49 PM
Acura_I-RS
Jun 6, 2003 04:40 PM
