collector mod
Old Jun 28, 2002 | 08:09 AM
2point6's Avatar
Default collector mod
How many of you are running a DC header for a H22a and have done the 2 1/2" collector mod? I have done it and noticed that I can now spin into 3rd gear instead of a chirp (I know this is a stupid way to measure an increase or not). I haven't done any dyno runs yet, But I also notice the A/F meter running a little leaner in the upper RPM range. The car feels a lot faster IMO... Any additional thoughts?
Old Jun 28, 2002 | 08:45 AM
Anyotherone's Avatar
Default Re: collector mod (2point6)
How did you modify it?
Old Jun 28, 2002 | 09:34 AM
2point6's Avatar
Default Re: collector mod (Anyotherone)
Basically, I had the collector on the B-pipe cut back to almost its widest point and had a piece of 2 1/2" piping welded there instead of the 2". I also had a 2 1/2" flex pipe added as well. I'll try to post a couple of picture later.
[Modified by 2point6, 8:51 PM 7/1/2002]
Old Jun 28, 2002 | 09:57 AM
Mike95lude's Avatar
Sweet
Lets see pics
Old Jun 30, 2002 | 11:42 PM
2point6's Avatar
Default Re: collector mod (Mike95lude)
I took the pics...Hopefully they will be up tomorrow. Sorry for taking so long. I will tell you this the improvment has been very noticeable
Old Jul 1, 2002 | 05:56 AM
se93's Avatar
Scott:
I want to see those pictures!!!
Regards,
Mark
Old Jul 1, 2002 | 10:18 AM
2point6's Avatar
Default Re: collector mod (se93)
Old Jul 1, 2002 | 11:35 AM
JG Luder's Avatar
that's it, my header goes to the exhaust shop before is gets bolted back on.
Old Jul 1, 2002 | 12:04 PM
illusion's Avatar
are you running some sort of high flow cat? or are you somehow merging it back to fit to the 2" stock cat?
Old Jul 1, 2002 | 12:06 PM
2point6's Avatar
Default Re: collector mod (illusion)
I am running a High flow cat.
Old Jul 1, 2002 | 03:15 PM
Mike95lude's Avatar
Which one?
Old Jul 2, 2002 | 07:09 AM
2point6's Avatar
Which one?
It is nothing special, It is called a Mor flow.
Old Jul 2, 2002 | 07:14 AM
IHaveTurbos's Avatar
So Scott do you still need the 3" Flex Section?
Old Jul 2, 2002 | 07:21 AM
2point6's Avatar
Default Re: collector mod (Hyundai4G63T)
Yes.
Old Jul 2, 2002 | 07:23 AM
Just checking I should be ordering some stuff this next week so I will pick one up for you. Also I got my new welder so I can hook you up on that also.
I'll post some pics of Mike's 3" Exhuast on Type R later.
[Modified by Hyundai4G63T, 4:24 PM 7/2/2002]
Old Jul 3, 2002 | 05:55 PM
DYI01's Avatar
thats mine that i modified
Old Jul 3, 2002 | 06:44 PM
SMSP's Avatar
Default Re: collector mod (DYI01)
Guys, this isn't a bad idea. But what I think you should try to do is not go so big with the tubing at the collector. The secondaries are only 1-3/4" and then dumping into a 2-1/2" tube is a pretty radical jump. Try going with some smaller tubing out of the collector and then stepping it up to your final size.
Old Jul 3, 2002 | 10:08 PM
2point6's Avatar
Default Re: collector mod (SMSP)
Hurry and finish the 4-2-1 header...HEHE! then we don't have to worry about this.
Old Jul 4, 2002 | 03:45 AM
SMSP's Avatar
I think Corey is going to sell the 4-1 on eBay soon.
Old Jul 4, 2002 | 04:43 AM
illusion's Avatar
but who would buy it when you need to cut that hole in the subframe? heh =]
Old Jul 4, 2002 | 06:15 AM
SMSP's Avatar
It will be sold with a sub frame swap.
Or maybe someone with a hybrid.
[Modified by SMSP, 7:16 AM 7/4/2002]
Old Jul 4, 2002 | 06:31 AM
se93's Avatar
How much?
Regards,
Mark
Old Jul 6, 2002 | 04:46 PM
Toretto's Avatar
I would like to see a dyno with the DC modded header. The DC header should make for real nice exhaust flow with a 2.5 dust collector welded on.
Old Jul 18, 2004 | 11:49 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Guys, this isn't a bad idea. But what I think you should try to do is not go so big with the tubing at the collector. The secondaries are only 1-3/4" and then dumping into a 2-1/2" tube is a pretty radical jump. Try going with some smaller tubing out of the collector and then stepping it up to your final size.</TD></TR></TABLE>
So what if we got a transition for the secondaries, to bring it from 1-3/4" to 2 1/2", and then a 2 1/2" collector.
Old Jul 18, 2004 | 11:59 AM
Inextricabledrvr's Avatar
i did this also and i notice a difference on the butt dyno. Especially in the high end. I replaced the flexpipe and put a 2.5". I did this a couple months ago and i will get it dynoed within a couple weeks.
Dc modded=
