Pistons
Old Jun 24, 2002 | 10:56 AM
JDM_4thGen's Avatar
Default Pistons
Hey i was just wondering something about pistions.
I have a h23a and was wondering if H22 pistons will fit and will it increase the compression ratio. What about type-S pistions??
thanks.
Old Jun 25, 2002 | 03:41 AM
PrecisionH23a's Avatar
Default Re: Pistons (JDM_4thGen)
Bore sizes are both 87mm for the h22 and h23 pistons. Personally, i would just buy an aftermarket piston... I would recommend JE, but they only come in 20 over for our engine, and you cant install these into your block due to the cylinder walls having to be honed out. The problem with this on the prelude block is the stock walls cant be honed out, they are fiber reinforced so you'd have to resleeve the block. Look for a company that makes 87mm pistons for the h23, as far as putting the type s ones in, im not sure about clearance issues or anything else bc im not too familiar on this topic...
Old Jun 25, 2002 | 07:20 AM
prospeed's Avatar
The H22a and Type-s pistons will slightly stick out of the block. About 2mm. good stuff
Old Jun 25, 2002 | 01:20 PM
2point6's Avatar
Default Re: Pistons (prospeed)
2mm is huge! do you mean .2mm?
Old Jun 26, 2002 | 10:59 AM
KTeller8's Avatar
Default Re: Pistons (2point6)
i have stock h22 pistons and rods now
great shape i just got aftermarket ones
email me
mkteller8@aol.com
ivan93egreppin210
Jul 9, 2012 06:43 AM
REDLUDE4WS
Feb 21, 2011 12:25 PM
JonDick
Oct 25, 2010 09:27 PM
JDMnegroCD5
Nov 24, 2008 09:05 PM
H-EK22
24
Feb 2, 2008 06:52 PM
