anyone ever have a problem with engine bogging or backfire?
Old Jun 21, 2002 | 09:56 AM
H22TurboNos's Avatar
Default anyone ever have a problem with engine bogging or backfire?
just swapped h23 to h22 but im still running h23 ecu. Car was running fine until just recently. The car started having trouble gasing and when i tried to gas to keep going the car started backfiring and i couldnt get very far. Now when i start up the car the car just keeps backfiring and sometimes it starts idling funny. At first we thought it was the plug wires because they werent giving enough spark, but i dont think that was the problem anymore. We also think it might be too much fuel pumping into the motor. The motor was running fine for about a month, we did compression check as well and all 4 cylinders were good. Any ideas?
Old Jun 21, 2002 | 10:06 AM
satan_srv's Avatar
Default Re: anyone ever have a problem with engine bogging or backfire? ([M]x007)
Wait so you have an H23 ECU? No VTEC? Dude that's crazy. An H23 ECU would be pumping more fuel into the engine because it's assuming the cylinders have 2. 3l rather than 2.2l.
Why don't you just buy an H22A P13 ECU? Then you would have VTEC, which is the reason you bought the engine right?
Old Jun 21, 2002 | 10:09 AM
Default Re: anyone ever have a problem with engine bogging or backfire? (satan_srv)
well im actually waiting for my freakin p13 thats y, so you think over time the h23 ecu made it pump too much fuel? that would sound kind of strange thought because h22 has vtec so i would assume that p13 would make it pump out more fuel than the h23 ecu
Old Jun 21, 2002 | 10:38 AM
satan_srv's Avatar
Waiting for the P13...that's too bad...
I'm thinking over time your plugs have become so fouled up from running rich that it's having a compunding effect on the engine performance. Pul your plugs..they should be verrrry black. At first you had good spark but now you don't...
VTEC would pump more fuel/fp but that's only when you're in VTEC. You can't run the VTEC cam until you get the P13, so you're just running the low cam which would have substantially less fuel requirements above 5000 rpms, and less than an H23 all around.
Old Jun 21, 2002 | 10:54 AM
Prelude Vtec 23's Avatar
If you install the plug wires incorrectly (not matching it with the correct cylinder and the distributer) then it will cause all the symtons you are saying. You may want to double check to make sure you it is hooked up correctly. I bet that is the problem.
Old Jun 21, 2002 | 11:16 AM
Default Re: anyone ever have a problem with engine bogging or backfire? (Prelude Vtec 23)
well for one thing, satan is right the plugs were black and there was some compound, the wires actually mitve been hooked up differently can you guys tell me the pattern for it? so i can try and switch it around i have 1 and 2 on bottom and 3 and 4 on top holes. by the way, is there a way i can drive around temporary until i get that p13? i havent been able to drive my car for about 5days now
Old Jun 21, 2002 | 11:31 AM
satan_srv's Avatar
If you had a V-AFC or S-AFC you could lean out your fuel mixture...
Hp.com is down or I would find you pic of the distributor and wires...
Old Jun 21, 2002 | 01:36 PM
10seconds's Avatar
Honda-Tech User
its because of the ecu get a p13
Old Jun 21, 2002 | 01:37 PM
10seconds's Avatar
Honda-Tech User
all motor 13.8@102
Old Jun 21, 2002 | 10:42 PM
Default Re: anyone ever have a problem with engine bogging or backfire? (jdmimports79)
so your saying, because of the ecu, after a month when the car was working fine and then all of a sudden started runnin like crap was due to the ecu?
Old Jun 21, 2002 | 11:13 PM
Finest's Avatar
Actually...the H22 has bigger injectors compared to the H23, so therefore the H23 ecu will deliver LESS fuel.
Get the P13.
Old Jun 22, 2002 | 04:46 AM
Mikey3000's Avatar
that's right.
bottom left = 1, bottom right = 2, top left = 3, top right = 4.
Old Jun 22, 2002 | 07:27 AM
JG Luder's Avatar
Default Re: anyone ever have a problem with engine bogging or backfire? (Boss Hogg)
my first guess would be plugs.
tj0825
Mar 7, 2011 12:07 PM
turb0hatch04
Mar 18, 2007 01:04 PM
junlude19
Nov 2, 2004 03:45 PM
gsrhatch530
Feb 6, 2003 12:03 PM
