Engine swap...
Old Jun 30, 2002 | 07:07 PM
Dead Possum's Avatar
Default Engine swap...
Right now I have an H23 non-VTEC and am gonna drop in a new engine. It's either gonna be an H22 or an H22A4. Is the extra 2 G's worth the 30hp gain?
Old Jun 30, 2002 | 07:13 PM
PrecisionH23a's Avatar
Default Re: Engine swap... (Dead Possum)
depends if you are going n/a or fi.
Old Jul 1, 2002 | 07:18 AM
ViZ's Avatar
ViZ
i wouldnt use a h22a4 i would use a h22a1 because the h22a4 from the 5th gen lude has and ODBII which means you dont get as much output from your upgrades like you would the h22a1 with the ODBI the 93-95 vtec motor is the best one to use..
Old Jul 1, 2002 | 07:47 AM
kevie88's Avatar
Default Re: Engine swap... (ViZ)
It's worth it for sure if you have an S model, but I'm not sure if it would be worth it for the si H23... I would probably do an h23 turbo build up.
Old Jul 1, 2002 | 07:50 AM
symba's Avatar
Default Re: Engine swap... (kevie88)
Depending on the condition of the h22a1 or a4 engine, i would consider rebuilding what you have and go turbo..Again, it depends on how much your engine swap is costing...Rebuild and turbo could easily break $8,000.00...But then again, an h22a4 with low miles plus labor could come to that figure also
Chico. Pitzer.
Mar 6, 2018 12:08 PM
bbp2024
Dec 27, 2006 12:39 PM
Tomservo
Jan 12, 2004 09:54 AM
nsx29
May 11, 2003 03:14 PM
armharm
Sep 28, 2002 09:46 AM
