New Cams ... problems need help.
Old Jun 26, 2002 | 11:50 PM
Alstare's Avatar
Default New Cams ... problems need help.
Well I put my Type-S cams into my JDM h22a tonight and everything went cool except i had a bit of a bitch with the timming belt but i manged to work through it. The problem is once I got everything all bolted back together and went for a test run it ran like shyt. it sputtered and died above about 3k and idled like crap so I checked my timing<ignition not cam> and set it to the big + sign on the flywhell which i imagine is 0. It still ran like poop so I adjust the timing to the 15 mark on the flywheel about an inch below the 0 mark and it ran good. So what's the deal? did I mis allign the cams a tooth or so on the timming belt or is this to be expected with the new cams? Also buy moving my timing so far how will this effect anything else? ie. air/fuel curve am i going to be running really lean now? any input would be greatly appreciated. I do not have access to a dyno nor do I have adj. cam gears. so i'm kinda limited on options. Thanks
Steeve_Civic
Jul 24, 2012 10:21 PM
slowredsol
Jan 22, 2009 11:43 PM
wangan_DA9
Nov 1, 2004 06:39 PM
mini-v-si
Apr 10, 2004 02:50 PM
shingles
Feb 16, 2004 03:57 PM
