compression ?
Old Jun 18, 2002 | 10:49 AM
areyouasian's Avatar
Default compression ?
i just ordered a jdm h22a with 10.6 compression...the motor is a 93-94, one of those years....i was wondering if i put in the type s pistons how much compression would it raise it too...someone told me it would run 11 like the type s....but someone else told me since the 93-94 is closed deck it will run 11.5...who was right?
Old Jun 18, 2002 | 11:36 AM
ludespeeder's Avatar
Default Re: compression ? (areyouasian)
it's a little over 11 in my car, but I had a lot of work done while everything was out. I think my car is running at 11.3:1 before the head work and 11.7:1 after everything was bolted together. You really can't get much above 12 and still run 93 octane from what I hear without some pretty bad detonation.
Old Jun 20, 2002 | 08:03 PM
Default Re: compression ? (ludespeeder)
from what i heard...11.5:1 is kinda pushing it on 93 octane thats y i wanted to run about 11.5 just wanted to know so i can see if i should stay with a stock head gasket or go with a two layer
Old Jun 21, 2002 | 10:42 AM
that's about right, I just pulled some of the timing and it idles fine, no detonation, also I went a cooler plug and it seemed to smooth it out some as well.
Old Jun 23, 2002 | 12:41 AM
Buckkaaaa!!'s Avatar
New User
haha 93.... you punks!!! us cali people are stuck with 91 11 is prob the highest safely
Old Jun 23, 2002 | 01:04 PM
Allstar's Avatar
New User
Default Re: compression ? (preludeboy)
I am just starting to piece my motor back togethor with a milled head and type S pistons. I should be around 11.5 to 11.7 compression. Tuning is key when you have this high of compression.
donnjuan2point2
Jun 25, 2003 03:22 PM
cornholioEK
May 21, 2003 07:22 AM
ZColeon
Apr 24, 2002 09:21 AM
Chuji
Oct 30, 2001 07:26 PM
