Lug nut problem
Old Feb 2, 2003 | 01:44 PM
TurboLude97's Avatar
Default Lug nut problem
I have a problem... I put extended lug studs on my car for my bogarts and the lug nuts for my regular wheels wont bottem out. (they are the tuner style) does anyone know if there are open ended lug nuts that are .75 inches outside diameter or less (with the socket on them)?? If they are bigger than that it will hit the wheel and i won't be able to tighten it at all. I need help!!
Old Feb 2, 2003 | 01:56 PM
jc836's Avatar
Default Re: Lug nut problem (TurboLude97)
Depending on the taper of the lug holes in your wheels-you might want to consider using McGard spline drive lug nuts and not use the top caps that come with them. The special socket is thin-wall and should work in the recess. To see what I'm talking about go to http://www.mcgard.com.
[Modified by jc836, 5:57 PM 2/2/2003]
540dude
Jan 11, 2013 08:45 AM
HCivExoo
Jan 18, 2009 06:36 AM
Sohc Driver
34
Dec 25, 2002 02:04 PM
