Shift Lights
Old Jan 31, 2003 | 06:08 AM
Georgethefierce's Avatar
Default Shift Lights
Anyone know of a good Quality Stand ALone shift light that I can wire to the stock tach?
Old Jan 31, 2003 | 08:23 AM
Smurfylude's Avatar
Default Re: Shift Lights (J01SH)
I think MSD has one and Autometer as well. Check Summit.
Old Jan 31, 2003 | 09:28 AM
TurboLude97's Avatar
Default Re: Shift Lights (Sushi X [TCL])
I have the autometer shift lite but for some reason it doesn't work above 4500 rpm. I ahve a pill kit from 6800-7400 and none of the pill will lite up. but the test pill works fine and if i put in on 6 cylinder mode so it will come on at 4500 it works. but if i put it on 8 cylinder mode so it comes on at 6000 it doesnt. and none of my pills work either. anyone have any ideas why?!?!
Old Jan 31, 2003 | 11:28 AM
KillerPrelude97's Avatar
I have an Auto Meter shiftlight and I have it set at 7400. It works fine.
Old Jan 31, 2003 | 11:38 AM
Default Re: Shift Lights (KillerPrelude97)
i think im not getting the required voltage to the shift lite at the higher rpms, so im going to try to rewire it.. btw what do you have the signal (rpm signal) wire hooked to?
Old Jan 31, 2003 | 12:10 PM
LudeyKrus's Avatar
Default Re: Shift Lights (TurboLude97)
I was looking at the Pilot one a while back...it's good as far as I've heard
Old Jan 31, 2003 | 12:15 PM
jc836's Avatar
The Autometer unit requires the control box-which you buy separately. Also you need to connect the unit to the BLUE wire on the distributor for the best signal. The box is available from Summit along with your choice of PLLs, extra cables and light units.
masijdm
Dec 17, 2008 12:04 PM
99silverbullet
Jun 9, 2003 08:29 PM
xXx Justin xXx
Mar 12, 2003 11:22 PM
speedymon
Aug 4, 2002 11:41 AM
veeDUB
Apr 2, 2002 05:51 PM
