Remove rear seats?
Old Jan 29, 2003 | 12:46 PM
optikal_blitz's Avatar
Default Remove rear seats?
Anyone know how to remove the rear seats? I have a 92 si. I see 2 clips under each seat, but am not sure what to do to make them release. Any help would be greatly appreciated.
Old Jan 29, 2003 | 01:32 PM
NammyBoy's Avatar
Default Re: Remove rear seats? (NatakuBlitz)
If it is anything like the 5th gen, press the seat down towards the clip, and there should be a tab that you can pull. Pushing the seat down will make it easier to pull the tab. Once you pull the tab, lift the seat...
~Nam
Old Jan 29, 2003 | 01:51 PM
Default Re: Remove rear seats? (NammyBoy)
Thanks, i will try this. If anyone can say different..speak up- thanks.
Old Jan 29, 2003 | 02:06 PM
Toda Built's Avatar
sometimes the tabs are hard to pull, so I took some pliers and pulled the tabs with them. (It just gives you a better grip on the tabs)
Hope that helps.
p.s. Putting my rear seat back in was a bitch.
Old Jan 29, 2003 | 02:09 PM
Default Re: Remove rear seats? (SH_LUDER)
oh, i see. Nam's advice helped it work out real well. I am making a 12" sub enclosure that uses the same mounting points as the seats, so i gotta get the metal parts up to size before i begin with the box. This is gonna be a lotta fun..
B18c5__Owns
Apr 24, 2007 07:01 PM
vinuneuro
Nov 8, 2005 07:53 AM
Nocturnal
Jan 7, 2003 11:42 AM
bananacruzier
Apr 17, 2002 11:22 AM
daniel89civ
Mar 13, 2002 05:11 PM
