mechanics
Old Feb 2, 2003 | 08:23 PM
darkvader's Avatar
Default mechanics
whats the level of difficulty of changing your own bent valves on a h22a
or if its too hard would a local honda dealer work on it
Old Feb 2, 2003 | 08:25 PM
tominos's Avatar
Default Re: mechanics (darkvader)
that job is most likely not for the novice mechanic. depends what you think you can do. if all you know how to do is change the oil, etc. then probably not for you, but if you can pull motors and swap axles, or what have you. then you can.
Old Feb 2, 2003 | 08:29 PM
Cottonwoodz's Avatar
I would find someone that has worked on hondas for awhile. And if your asking how hard it is, then I would deffenatly leave it alone.
Old Feb 2, 2003 | 08:38 PM
darkvader's Avatar
Default Re: mechanics (Cottonwoodz)
well everyone has to start somewhere...
does the helms manual cover that topic
Old Feb 2, 2003 | 10:12 PM
papa_smurf's Avatar
yea everybody has to start somewhere but this is not that place. what these guys are trying to tell you is that you can quickly get over your head if you get into a project like this, not to mention that most mechanics will not tackel a big project like this if it is already halfway done. for fear that you fucked something up that they can't see yet and they will get blamed for it. some very important things that you don't know without pulling the head is if you have damaged a valve seat (they need to be pressed in, which requires special equpiment) your head could possible be physically damaged (warped cracked, which would require further machining) your pistons could quite possibly be scuffed maybe even cracked, and if one of the valve heads broke off you could have possibly eve damaged teh block, pretty much trashing your engine. IMHO not a good place to learn how to work on cars, mos def not without a knowledgable guide. oh yea and all these things are extreme worst case scenerios, don't mean to scare teh **** outta ya.
oldskoolchris
16
May 30, 2019 11:34 PM
fleabag
Jan 20, 2010 03:36 AM
accord99power
May 7, 2009 09:40 PM
IntegraBoy04
Sep 17, 2003 05:48 PM
Steve
Jul 9, 2001 01:41 PM
