Turbo Question
Old Feb 1, 2003 | 09:29 PM
smslude's Avatar
Default Turbo Question
I have been debating recently if i should turbo my car or not. I was wondering if i would have to have a fully built motor before i could run boost. Ive got a 97 Vtec with 62k miles on it.
thanks for any replies.
Old Feb 2, 2003 | 03:38 AM
Arch-Angel's Avatar
Default Re: Turbo Question (smslude)
while it is always best to reinforce the engine, it is possible to run low boost safely with very minor mods
at very least lower the compression and resleeve the block
Old Feb 2, 2003 | 06:05 AM
PrecisionH23a's Avatar
if your just looking to run 8 psi around the street, you should be fine with stock internals. do a cylinder leakdown test first on your car and see how your compression is holding up though first. other then that, your basic fmax or drag kits will allow you to safely boost 8psi, if you have the money go with a v-afc so you can tune your fuel curves. or if you wanna go all out, get the hondata.
Old Feb 2, 2003 | 06:50 AM
smslude's Avatar
Default Re: Turbo Question (GudeH23a)
I plan on having all the bolt ons and a Vafc before i do anything. Is it possible to get a decent turbo kit for under 5,000 installed?
Old Feb 2, 2003 | 08:27 AM
BoostedH23a1's Avatar
anthony... u need some commas in the message above your avatar... and get on AOL need to talk to u
ghostcivic
Jul 19, 2007 03:23 PM
Th3savinday
May 2, 2007 07:24 AM
jdjustme
Mar 9, 2007 01:05 PM
92integraVTECgsr
Sep 17, 2005 10:13 PM
strepto
Sep 3, 2003 06:21 AM
