slows down w/vtec
Old Sep 12, 2003 | 04:25 PM
stRodda's Avatar
Default slows down w/vtec
i have a 91 accord and im still using the stock fuelpump. when it hits vtec it feels like its slowing down, is that because the stock pump cant feed enough fuel?
also, when i connected my exhaust, an apex ws, the idle was rough and sometimes stalled out. but when i ran it without the muffler, it runs ok. is the backpressure causing some sort of problem?
Old Sep 12, 2003 | 06:02 PM
LudeBoyLeRoy's Avatar
Default Re: slows down w/vtec (stRodda)
You are very vague describing your set-up.
First I would specify what motor you have...91 Accords didnt have VTEC.
I assume you have an H22 Swap but you dont say that anywhere so for all we know its an F series 2.2 VTEC from a 94 accord w/like 145hp.
Just a suggestion.
PS: if it IS an H22 swap I would say you prob should get the right fuel pump - the F22 fuel pump likely is not good enough (I could be wrong)
Old Sep 12, 2003 | 07:57 PM
93accordEX's Avatar
Default Re: slows down w/vtec (LudeBoyLeRoy)
accord fuel pump is perfectly fine with an h22 swap. unless it was bad to begin with but if you had a brand new accord fuel pump it would be perfectly fine.
MJT805
May 29, 2009 11:11 AM
mozzandherb
Apr 2, 2006 03:59 PM
cheezoto
Feb 11, 2004 02:36 PM
monkey804
Oct 7, 2003 01:03 AM
KTeller8
Jun 8, 2003 01:24 PM
