ass load of compression
Old Sep 16, 2003 | 06:58 AM
machine4321's Avatar
Default *** load of compression
i did a comp tes the other day right after driving it ....i got upwards of 270psi..some 260...i though it must be my shitty gauge...
so i went to my buddies work and they have a snap on gauge so i drove it down the block and just did one cylinder and i peged the gauge at 250.....
what is going on here...and why has my compression gone up since i got the motor....used to be around 220-230....
on that note with that much compression why is my car so dam slow
im hoping it could be build up on the valves cause the pistons look pretty clean since i got the motor
Old Sep 16, 2003 | 08:19 AM
Sephro's Avatar
Default Re: *** load of compression (machine4321)
yeah sounds to me like sticky valves. I would take care of that ASAP!
Old Sep 16, 2003 | 09:35 AM
flyrod's Avatar
Default Re: *** load of compression (Sephro)
You could have a lot of carbon in the combustion chambers. Does it burn oil?
Old Sep 16, 2003 | 06:32 PM
no.not really...i valve seals are if but only do it seldomly.....
other than that i run 5 w 20 moblie 1 and it seems to "use oil"...doesnt burn any while driving
Old Sep 17, 2003 | 05:25 AM
sorry i run 5w30 mobile 1
any other thoughts on this ....thats pretty high reading and im starting to worry about detonation i havent heard any but you never know
Old Sep 17, 2003 | 05:54 AM
fastludeh22's Avatar
Default Re: (machine4321)
have you checked the valve lash? i know when mine were too tight, i had way low compression.
maybe there too loose and not opening all the way.(just taking a guess here)
Old Sep 17, 2003 | 07:50 AM
TraKtioN's Avatar
did you pull the fuel pump fuse so it doesnt spray fuel inside and raise your compression?
Old Sep 17, 2003 | 08:39 AM
LudeyKrus's Avatar
Default Re: (TraKtioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">did you pull the fuel pump fuse so it doesnt spray fuel inside and raise your compression?</TD></TR></TABLE>
That wouldn't raise it too much....I have done it both ways, and it wasn't that much different either way, so I just keep the fuse in for ease.
Old Sep 18, 2003 | 08:37 AM
yes ive done that (the ecu fuse)
this worrys me cause i plan on going turbo this winter ...
Old Sep 18, 2003 | 08:43 AM
AndyD's Avatar
LOL The name of this thread made me laugh. I thought you had a health related issue. LOL
Old Sep 18, 2003 | 08:46 AM
hehehe
next project topic....ive got gas
Old Sep 18, 2003 | 02:55 PM
racebum
Apr 2, 2012 10:17 PM
sanjoseDA9viet
Dec 16, 2006 03:34 PM
sanjoseDA9viet
Northern California (Sales)
Dec 12, 2006 01:47 PM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
Nameless RB26
Apr 10, 2003 01:53 PM
