H22a Problem
Old Sep 13, 2003 | 03:07 PM
h22a1300177's Avatar
Default H22a Problem
Please help me, I swap a h22a into a 92 Accord, and everything was done! The car runs weird, when I didn't put in the gear, I can rev up to 8,000rpm. But when I try to drive it, (put in 1st gear) the car can only drive 5-10mph (The rpm won't pass 2k, if I step on the gas, it just like nothing, won't move or anything.). 2nd gear the same, won't pass 5-10mph. The only way I can rev the rpm over 2,000 while sitting in gear is press down the clutch. Once I release the clutch, the car will not run again.... until it drop below 10mph. Please help me... what is my problem!!
Old Sep 13, 2003 | 07:52 PM
machinehead's Avatar
thats gotta be a clutch/tranny problem. or your brakes, are your brakes locking up?
Old Sep 14, 2003 | 07:27 AM
Default Re: (machinehead)
No... clutch/tranny/ brakes are fine! (100% fine)
Old Sep 14, 2003 | 08:18 AM
satan_srv's Avatar
Default Re: (h22a1300177)
I;m thinking your ecu and/or wiring is messed up...
Old Sep 16, 2003 | 06:12 PM
OptimusPrime2k's Avatar
Default Re: H22a Problem (h22a1300177)
check the grounds in your distributor....they can cause it to redline early
Old Sep 16, 2003 | 08:49 PM
Default Re: H22a Problem (OptimusPrime2k)
Well... really dunno what will the problem be.
Hey .. is Anyone notice!!!
I saw someone who connect the VTEC SOLONOID to a relay instead on ECU. What are they try to do???
h22silvia
Aug 18, 2006 03:46 PM
PrettyFastRide
13
Jul 13, 2006 06:30 AM
TEGGRY
Mar 24, 2006 04:21 AM
deejaycherub
Oct 27, 2004 03:19 PM
h22a1300177
Sep 16, 2003 09:05 PM
