Timing Belt
Old Sep 11, 2003 | 05:27 PM
JaiDieM's Avatar
Default Timing Belt
When changing timing belt.....do I need to change anything else or should I just change the timing belt???? (i.e. Water Pump, Tensioner, Balance Shaft Tensioner)
Old Sep 11, 2003 | 06:38 PM
Jeff99Base's Avatar
Default Re: Timing Belt (LuDeAcrOus29)
Do it all. The labor to get the water pump changed is basically the same as the labor to do the Timing Belt. The waterpump is a $60 part, the general view is you might as well do it while your in there doing the belt anyway.
I just had my belt done at 65k and I also had the autotensioner done, the balancer shaft belt, the water pump and the valve seals all done at the same time.
Old Sep 11, 2003 | 06:48 PM
PrecisionH23a's Avatar
Default Re: Timing Belt (Jeff99Base)
honda OEM pumps run around the 90$ range
Old Sep 11, 2003 | 06:55 PM
gsr-HF's Avatar
Default Re: Timing Belt (GudeH23a)
also change the cam and crank seals, they tend to leak after 100,000 miles.
dj-t
Feb 20, 2012 07:13 PM
honda2112
Apr 15, 2010 05:10 AM
petrv
May 10, 2006 03:24 AM
zracer240
Aug 1, 2005 10:07 AM
1hotintegra
Jun 16, 2003 03:10 PM
