Got a problem ? what do u think?
i got a 2000 prelude sh with JRSC, the thing is that when i hit max boost there is a niose that come from the Engine BAY . Frist i thought it was the belt , then one of my friend thought it was pinnging. than i took another friend for a ride, and this time i made it ping by ******* with the timing. So i know its not the timing. but another friend thing its the belt hiting the brake lines, when the engine is torquing.
2? is what kind of plugs are u guys running with JRSC ???
thanx
Modified by redmethods at 11:59 PM 9/14/2003
thanx
stop playing around, lol
Anyways, I would take racerx's advise and take it to a shop to get checked out, or even better, have the person who installed it take a look at it and describe the problem your having with your car to the mechanic. Unless of course you installed it then take it to a reputable shop so they can have a look at it.
with the supercharger there is a pully that run by the steel brake lines that are cover with rumber. well when there is a load on the engine, the engine tourqe back and the pully his hiting the lines and stut tower. I can tell because its is leaving marks. That is what i think is happen (i think), & making the noise ( i hope)
it isn't the tower strut bar it's the strut tower, the out side of it ( if that helps) and yes the line are zip tie back are far as they will go. Also i do need motor mounts,any ides where to get some and what kind???
i would get some upgraded motor mounts if i were you. the stock ones are designed for stock HP and TQ. you just added another 40% with the JRSC. that sounds like a very good possibility of the problem. i wouldnt drive it much at all until you get the new mounts in. HASPORT has a good name in mounts. pricey, but a good name. not sure if they make them for the lude but it cant hurt to try. maybe just get the inserts.
EvenStar
Mar 27, 2009 04:01 PM
Chase2
Nov 14, 2007 12:26 PM
illi Adik
Nov 22, 2002 09:45 PM
