factory 5th gen cd player problem
can someone please answer my question real quick, i just got my 98 prelude Type SH back from the dealer cuz they fixed the tranny and the cd player dont work it says err -3 and it doesnt play or nothing please help
simple, reset the code, or better yet, from MY own experience, reset the ecu, then YOUR code will reset the radio and you are done.
Good luck.
Good luck.
1. reset your battery
2. Find the cd player code
3. Enter it
To fix your tranny they have to disconnect your battery, everytime your battery is disconnected your cd player will be reset.
3. Enter it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naujcdl »</TD></TR><TR><TD CLASS="quote">unplug the negative hook or whatever it is on the battery.
l8r.</TD></TR></TABLE>
so thats how i reset my ecu? and once i do that the radio would work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadaRed »</TD></TR><TR><TD CLASS="quote">It has to be the code specific to your stereo, just take it out, read the serial number, take it to a dealership and get it! </TD></TR></TABLE>
I didn't buy my car from a Honda dealership I bought it from a Toyota dealership. A Honda dealership would probley charge me money to get the code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naujcdl »</TD></TR><TR><TD CLASS="quote">or it is a sticker on the globe compartment door, as you open it, you will see it...mine is that way.
good luck.</TD></TR></TABLE>
how many digits is the radio code?
Thanks all you guys for your feed back IM trying to get my stereo working as fast as possible cuz its a bitch driving with no stereo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_SH »</TD></TR><TR><TD CLASS="quote">thanks is there any other way besides taking out the sterero to get the serial number? a</TD></TR></TABLE>
nope, listen, you take the plastic trim piece around your a/c - radio unit (use a soft cloth and a flat head screw driver to pry that piece out, then you should see two screws holding the radio, take that out, obviously, then you should see the serial on the radio).
Once this is done, you need to go to a HOnda dealership and give them that serial number, plus your proof of ownership, if you don't drive there. DO NOT PAY for them giving you a stupid code, you must not pay, if they charge tell them to suck off...
Done.
Done.
also, when you open your glove compartment, do you see a little sticker with some numbers on it??? on the door itself???
if so, the top one with a 5 digit is your radio code.
Good luck
Good luck
ya i know they said they would fix it monday they also hit a pole in my car while it was over there and when they painted it,there was bubbles between the rear bumper and the car
VtecPMP
Aug 30, 2003 09:27 AM
