Ignition Problem
Old Nov 2, 2003 | 11:58 AM
Lude-Conduct's Avatar
0861 OORAH!!!
Default Ignition Problem
Is it true that like a heavy key chain can cause the things in the ignition to mess up? Because I used to use a heavy key-chain till my good 'ol friend told me to take it off. Now its a bitch to start . I mean, like you can't even start it now . It was working okay last night, but now it wont budge. The key wont budge, I tried, my dad tried, my mom tried, but to no avail. Can anyone verify if that can happen and help me here?
Old Nov 2, 2003 | 12:05 PM
RHD_BB4T's Avatar
Default Re: Ignition Problem (Lude-Conduct)
If I'm decifering your message correctly *?* then what you are saying is that when you turn the key in the lock cylinder, it won't turn, correct? If that's the case, I've never heard of something like that happening from a heavy keychain. Try to turn the key 180 degrees and try that (that's what I have to do with mine *sometimes*). It could be that you need to get the four digit code from the lock cylinder and have honda cut you a new key... or, it could be the lock cylinder itself. Does the key work in every other lock on the car? Just trying to help you narrow it down to something specifice... HTH
Dan P.
Old Nov 2, 2003 | 12:08 PM
0861 OORAH!!!
Default Re: Ignition Problem (Dan_P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan_P &raquo;</TD></TR><TR><TD CLASS="quote">Try to turn the key 180 degrees and try that (that's what I have to do with mine *sometimes*).</TD></TR></TABLE>
The key is unturnable.
The key works everywhere else.
Old Nov 2, 2003 | 12:14 PM
SKDRCR's Avatar
i'm sure you probably tried to wiggle the steering wheel
to get it to work didn't you
Old Nov 2, 2003 | 12:15 PM
0861 OORAH!!!
Default Re: Ignition Problem (SKDRCR)
Um.......of course.
-runs off to try-
Old Nov 2, 2003 | 12:17 PM
0861 OORAH!!!
I geuss my dad already tried that.
Old Nov 2, 2003 | 12:18 PM
4bidden's Avatar
Try it again.....move it left/right as far as you can while trying to turn the key.
Old Nov 2, 2003 | 12:19 PM
0861 OORAH!!!
Default Re: Ignition Problem (4bidden)
Ok, I'll go try now.
Old Nov 2, 2003 | 12:24 PM
0861 OORAH!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Try it again.....move it left/right as far as you can while trying to turn the key.</TD></TR></TABLE>
THANK YOU!!!!!!!! It worked, YAY!
Old Nov 2, 2003 | 07:35 PM
Boostindrvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude-Conduct &raquo;</TD></TR><TR><TD CLASS="quote">
THANK YOU!!!!!!!! It worked, YAY!</TD></TR></TABLE>...
....i knew that was coming...
Old Nov 2, 2003 | 08:07 PM
fe519's Avatar
Default Re: Ignition Problem (Boostindrvr)
oh my goodness...
Old Nov 3, 2003 | 08:57 AM
SKDRCR's Avatar
Default Re: Ignition Problem (fe519)
This thread is dead
Old Nov 4, 2003 | 03:25 PM
0861 OORAH!!!
What? I was messing around, lol.
Old Nov 4, 2003 | 07:55 PM
^jefs0ng's Avatar
Banned
HAHAHA my friend who used to give me rides to school called me once saying he couldn't start the car so we got a ride from someone else.. Joking, I said "you probably locked your steering wheel huh.. you can't turn your wheel at all huh" and he goes 'oh ****..' HAHAHAAH
daniel reich
Acura TL, RL & ZDX
Sep 13, 2017 03:37 PM
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
2.2SICKLUDE
Honda Motorcycles
Nov 1, 2006 11:27 PM
M@
Nov 17, 2005 03:39 PM
qcktegls
Jan 9, 2005 03:52 PM
