Is this all?
Old Nov 1, 2003 | 06:54 AM
FoxRiderH22A's Avatar
Default Is this all?
Hey i was wondering if you more experienced people out there could answer this question for me. Are these all the parts i need in order to have my timing belt changed? I figured i might as well do all the belts at once. Thanks.
timing belt
balancer shaft belt
alternator belt
power steering belt (i need that one though)
water pump
tensioner
Old Nov 1, 2003 | 07:59 AM
fastludeh22's Avatar
Default Re: Is this all? (FoxRiderH22A)
i'd dot he oil pump also. also look into converting to manuel tensior, much better then auto tensior.
do a search, there is a lot out there
edit: to get more responses, and to help our serach feature, title the theards more spicificlly.
Old Nov 1, 2003 | 10:16 AM
are the tensioners also called adjusters? where can i get the manual ones instead of the automatic ones? thanks.
Old Nov 1, 2003 | 10:25 AM
SUB-0 H23's Avatar
might as well change the cam and cranks seals
Old Nov 1, 2003 | 10:35 AM
JBG's Ferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FoxRiderH22A &raquo;</TD></TR><TR><TD CLASS="quote">are the tensioners also called adjusters? where can i get the manual ones instead of the automatic ones? thanks.</TD></TR></TABLE>
Get a manual tensioner from an h23.
Security81
May 26, 2008 09:34 AM
Stuartz
May 1, 2007 07:48 AM
zracer240
Aug 1, 2005 10:07 AM
raylude
Sep 21, 2004 11:27 AM
