Fuel Filter changing
I have a 1994 2.2 VTEC import.
I want to change the fuel filter and know that it is on the right of the fuse box from what i have read..?
Can someone send me a pic of it and a step by step instruction of how to change it?
thanks
thanks
it's the little canister thing to the right of the fuse box i 14 mm wrench will do the trick on th top fuel will leak out, i think there is 4 10 mm bolts holding the bracket on it's really simple to change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">I did a search on this particular topic and found about 20 hits in this forum. Check it out.</TD></TR></TABLE>
lol
lol
its a pretty straight forward job. although its in an awkaward place and the bolts/nuts might be little hard loosen at first. other than its easy. pretty self explanitory
The easiest way to remove it will be with a line wrench, not your run of the mill open ended wrench. A line wrench has two more sides to keep it from slipping on the nut
not to thread jack but how often should the fuel filter be replaced? my car has 98xxx miles on it and ive owned it for the past 20xxx and never done it and i dont think the owner before me did either...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2XDreams »</TD></TR><TR><TD CLASS="quote">not to thread jack but how often should the fuel filter be replaced? my car has 98xxx miles on it and ive owned it for the past 20xxx and never done it and i dont think the owner before me did either...</TD></TR></TABLE>
Off the top of my head i beleive it is recommended every 30,000 miles.
So in other words, CHANGE YOUR FUEL FILTER
handa
Apr 3, 2005 03:27 PM
andrewasf77
Dec 6, 2002 10:30 PM
