pcv block???
Old Aug 2, 2004 | 04:11 PM
hOndafienD 04's Avatar
Default pcv block???
would i be able to put a plug both on the pcv valve and intake manifold so that it would bring in less air, and not have any damage done to my h23????
Old Aug 2, 2004 | 04:53 PM
jmcclell's Avatar
Default Re: pcv block??? (hOndafienD 04)
No, your bottom end has to be able to breath. It needs the pcv system to stop the build up of moisture and blow-by gases contaminating the oil.
Blocking the breathers will also cause an unhealthy build up of crank pressure, which will "push" oil past your piston rings and cause the engine to burn oil Excessively.
Try it for a laugh, if you dont believe me
Old Aug 2, 2004 | 04:59 PM
i believe you lol...what if i put a block on the manifold and leave the pcv on the valve cover but not connected to the manifold??
Old Aug 2, 2004 | 06:06 PM
user 9782082308's Avatar
Default Re: (hOndafienD 04)
This is very good reading on the subject.
https://honda-tech.com/zerothread?id=697502
Old Aug 2, 2004 | 06:09 PM
thank you sir
Old Aug 2, 2004 | 07:00 PM
Yield's Avatar
get a pcv catch can if you want to improve things but do not plug them up.
jtm509
May 30, 2010 11:19 AM
gsr dood
Mar 20, 2006 07:24 PM
Jeff C
Nov 4, 2002 12:47 PM
Turbocivic98
May 10, 2002 04:06 AM
xtrafastcivic
Mar 25, 2002 01:22 PM
