Amplifier power wire help
Old Aug 1, 2004 | 10:08 PM
Siegfried's Avatar
Default Amplifier power wire help
Hi, I would like to install an amp in my 93 mude,I would like to know if I have to make a hole for the power cable or is there already a hole that I can use for a 4 gauge cable.
Thanks
Old Aug 1, 2004 | 10:16 PM
Slipknt777's Avatar
Default Re: Amplifier power wire help (Siegfried)
Im sure there is a hole...but i just drilled one.
Old Aug 2, 2004 | 12:27 AM
Nikoli's Avatar
Default Re: Amplifier power wire help (Slipknt777)
there should be plugged hole on the passenger side of the firewall. just look around you should see it
Old Aug 2, 2004 | 08:14 PM
Siegfried's Avatar
Default Re: Amplifier power wire help (Deckedlude)
somoene tell me wich hole he use and were it is, I don' t want to drill one
pleaze
Old Aug 2, 2004 | 10:22 PM
Chris1091's Avatar
there's plenty of holes on the firewall. I highly advise not drilling through your firewall.
Old Aug 3, 2004 | 09:32 PM
Siegfried's Avatar
Default Re: Amplifier power wire help (Chris1091)
I still don' t know where there' s a hole I can use, is there one that has an easy access on both side of the firewall, looks like there' s a hole behind the fuse box on the passenger side but don' t know where it goes out inside of the car. it' s behind the dash, it also require to remove the fuse box and then the dash.
I' m looking for a hole that is easily accessible from both side, or at least 1 side.
PLEASE tell me where it is. There shoulb be one person who have install an amp using an existing hole.
Old Aug 3, 2004 | 09:42 PM
Nevaeh's Avatar
if you pull back the carpet behind the clutch, there might or might not be some padding, if so behind it is a whole exactly big enough for a 4 gauge wire to fit through in the ipper left corner of the floor board of the drivers side. hope that helps
turbosiek9
Audio / Security / Video
Jan 11, 2009 12:11 PM
benzo_tek
Sep 22, 2008 02:56 PM
JordanCivic
Sep 23, 2007 11:56 AM
Takumi Fujiwara
13
Aug 3, 2006 11:40 AM
Ekco
Jun 13, 2002 12:47 PM
