Weird Shaking...
Old Aug 4, 2004 | 01:23 AM
mikeds122's Avatar
Default Weird Shaking...
I have '92 SR (si) with a JDM H22A swap.. Recently, whenever there is a sufficiant load on the motor, the whole front end of the car starts to shake..
In neutral, the motor revs smooth and normal... I started to notice this a couple days ago when going up a hill.. started to shake, and now whenever i give it gas it shakes.. as rpm increase and power with it, the shaking gets a lot worse almost to the point where I can't read the gauges anymore.
Any ideas of what this might be? My best guess is a loose engine mount?
Old Aug 4, 2004 | 01:39 AM
diluted's Avatar
Default Re: Weird Shaking... (mikeds122)
how are the motor mounts?? maybe that could be the cause of the problem.
Old Aug 4, 2004 | 01:47 AM
mikeds122's Avatar
Default Re: Weird Shaking... (diluted)
Yeah, thats my best guess... Hopefully that's all it is, as that would probably be the least expensive problem to fix. Any other ideas?
Old Aug 4, 2004 | 10:29 AM
sandusk's Avatar
mine does this too, but only from like 20MPH to about 50MPH. it only starting doing this after i got it back together from when i flew off the road with it. i thought it was a halfass alignment that was causing it.
Old Aug 4, 2004 | 11:35 AM
-Bionic-'s Avatar
Former Sponsor
Does it make a noise?
Sounds like the mounts. How many miles do you have on them?
Old Aug 4, 2004 | 01:02 PM
Behan's Avatar
Default Re: (-Bionic-)
it could also be a bad cv axle, i had a similar problem and it was my inner cv axle.
https://honda-tech.com/zerothread?id=836896
B20HmongHatch
Jun 26, 2012 02:25 PM
El_Arsonista
May 15, 2007 08:35 AM
T_bones
Sep 5, 2005 03:11 PM
rexorz
Feb 18, 2003 01:35 PM
BigBank420
Dec 4, 2002 12:00 PM
