dule stage vtec ECU
Old Oct 18, 2004 | 06:36 PM
92hondalude's Avatar
Default dule stage vtec ECU
i was looking up P13s and i saw a dule satge vtec they said it makes vtec kick in hard. Dose anyone have a dule stage ECU. If you do tell me if it is a big difference in vtec kick in.
Old Oct 18, 2004 | 06:37 PM
4bidden's Avatar
Default Re: dule stage vtec ECU (92hondalude)
:searches for bs flag smiley:
Old Oct 18, 2004 | 06:38 PM
mgags7's Avatar
never heard of it, lets see a website
Old Oct 18, 2004 | 06:40 PM
Default Re: (mgags7)
ebay type in p13
i will get URL in a min
Old Oct 18, 2004 | 06:42 PM
Default Re: (92hondalude)
http://cgi.ebay.com/ebaymotors...33596
Old Oct 18, 2004 | 06:46 PM
BrokeLude's Avatar
Since VTEC is either on or off, how do you think it could possibly work in this "dual stage" scenario?
Old Oct 18, 2004 | 06:47 PM
v4lu3s's Avatar
RTFM
its not possible to have 2 vtec engagement points unles you have a d15b sohc vtec engine that is 3 stage vtec.
on the h22a the vtec is either engaged or NOT engaged, meanign 2 stages.
Default Re: (BrokeLude)
thats what i was thinking so that why im asking you all
Old Oct 18, 2004 | 06:49 PM
Default Re: (v4lu3s)
so should i get this or a stock one.
i was thinking this one also because the vtec kicks in at 4600 instead of 5000 or 5100
Old Oct 18, 2004 | 06:52 PM
v4lu3s's Avatar
RTFM
i have teh skunk2 usdm ecu map, the xs usdm ecu map, a dinan usdm map, and 2 versions of the spoon map as well as the ks-rom map, its hard to tell any of them apart....id start with a stock one to be honest, it can easily be rechipped later if needed.
Old Oct 18, 2004 | 06:56 PM
to chip a ecu do you need it profecionaly installed or do they snap in place?
Old Oct 18, 2004 | 07:27 PM
matix's Avatar
I think its just gotta be socketed then you can change chips out. Just get a Vafc.
Old Oct 18, 2004 | 10:03 PM
stRodda's Avatar
Default Re: (matix)
the dual stage has to do with throttle %... if youre under a certain percentage itll engage higher, and if youre at wot itll engage lower.
but either way, never buy some bullshit ecu off ebay. how can they possibly set a custom fuelmap to run a motor when they have no idea whats done to it. all it does is add fuel, which is stupid... lean makes power
DrGthumbEX
Aug 8, 2012 12:58 PM
88CRX951
Honda Civic (2001 - 2005)
10
Nov 11, 2011 03:42 AM
jmeyer99
Oct 14, 2010 08:35 AM
digitalhav0c
Apr 9, 2002 11:05 AM
