Wheel question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prayludin »</TD></TR><TR><TD CLASS="quote">I mean does the rim fit on at all. like will the holes for the lugs line up?</TD></TR></TABLE>
According to this site Konig R wheels will fit the Lude, but you HAVE to get the 5 stud 114.3 mm PCD for the wheel to fit 5th gen studs, these come with 40mm offset which will be fine.
http://www.wheelspecs.com/specs/wheelmodels/205
Are you planning on 15", stock 16" or upsizing to 17" ? Because they are available in all the diameters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm »</TD></TR><TR><TD CLASS="quote">dude your a flipping idiot</TD></TR></TABLE>
you'RE
you'RE
If you want a set of cheap steel 15" wheels for winter use that you can be certain will fit, get some steelies off a Honda CR-V they fit for sure and won't be much dearer if at all.
.::miLan
May 16, 2005 04:30 AM
