will this be a camber problem???
Old Oct 18, 2004 | 07:42 PM
jdm_loser's Avatar
Default will this be a camber problem???
i would like to order the H&R race springs for my 92 si 4ws, but they say the front is 1.9 drop and the back is 1.6. will the 1.9in drop cause camber problems in the front? i dont trust camber kits and i dont want to be replacing my tires all the time due to camber wear..... anyone know how low before camber problems?
Old Oct 18, 2004 | 09:43 PM
draxxus07's Avatar
Default Re: will this be a camber problem??? (jdm_loser)
i dont know how long it will be before u start having tire problems but ive heard from different ppl that for as long as ur under a 2 inch drop u dont need a camber kit that bad but thats just what i have read, of course anytime u lower ur car it will put more stress on the car/tires so dont be suprised if u have to change ur tires more often than normal
Old Oct 19, 2004 | 12:45 AM
es_squared's Avatar
i have the same springs and yes you will need a camber kit. for the front only tho, rears are fine.
Old Oct 19, 2004 | 01:10 AM
bad-monkey's Avatar
i think it'll be alright.
should put you at roughly -1.5 degrees of camber, which isn't so bad.
Old Oct 19, 2004 | 08:43 AM
93_ludesi's Avatar
Default Re: will this be a camber problem??? (es_squared)
Yep, I have same springs also...didn't do camber kit - needed new tires within 6 months. Have camber kit now!
Old Oct 19, 2004 | 11:28 AM
jdm_loser's Avatar
Default Re: will this be a camber problem??? (93_ludesi)
thanks guys and for the camber kit what kind do u guys trust??? skunk2, ingals
Old Oct 20, 2004 | 12:38 AM
es_squared's Avatar
most people go for the ingals
Old Oct 20, 2004 | 12:46 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">most people go for the ingals</TD></TR></TABLE>
well, there is no skunk2 kit for our cars.
the choices are ingalls (anchor bolts) vs. spc (ball jt) for the fronts.
the spc's are preferred, since the ingalls has a tendency to make your upper control arm beat the crap out of the wheel well.
the spc does it too, but it's not as bad.
Jesterian
Sep 28, 2006 08:05 PM
E36 Guy
16
Apr 7, 2006 09:58 AM
GUNNER666
Jul 28, 2004 08:26 AM
DC4 teg
Dec 17, 2003 04:17 PM
Ferrell
Mar 18, 2002 05:52 AM
