Too high of compression for boost?
Old Oct 18, 2004 | 02:39 PM
RA062424's Avatar
Default Too high of compression for boost?
I got a JDM 22 type-s engine and have plans off boosting it here in the near future. The only problem is that the compression I hear is too high to boost. Plus I've also heard that in the 22 if you replace the pistons you'll have to resleave the block. Is this true? And whats the best ratio when it comes to running a good 6-8 psi every day?
Old Oct 18, 2004 | 02:54 PM
Matgallis's Avatar
Default Re: Too high of compression for boost? (rseaburgh)
I don't normally like to say this but seriously please search. Also make your way into the forced induction forum section and read away. A lot of good info in there.
About your question. 11:1 compression is pretty high for boost. However I'm sure with <U>VERY</U> good tuning you could be ok with 4-5 lbs of boost. ANy higher and problems will occur.
Yes resleeving is indeed a necessity when running forged pistons. Best ration is 9:1 IMO Others might disagree
Old Oct 18, 2004 | 03:09 PM
draxxus07's Avatar
yea, high compression is good for n/a, low for FI...
im pretty sure u can swap ur pistons out for usdm pistons on a stock prelude if u dont wanna resleeve ur block
matter of fact il trade u my set for urs, since i wont be buying a turbo anytime soon =P
Old Oct 18, 2004 | 11:48 PM
SKDRCR's Avatar
Default Re: Too high of compression for boost? (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">
I agree
Old Oct 20, 2004 | 10:46 AM
RA062424's Avatar
Default Re: Too high of compression for boost? (SKDRCR)
Thanks for the help
stefz
Jan 29, 2009 08:22 AM
snaileg
Nov 8, 2006 04:11 PM
7rrivera7
Apr 20, 2004 03:46 AM
00TypeSH
Feb 10, 2003 02:13 PM
7rrivera7
Oct 23, 2002 06:58 AM
